Upgraded to V57.0 takes 10-20+ secs to open new tab etc. Why? Win 10
  • 2 balasan
  • 17 ada masalah ini
  • 3 paparan
  • Balasan terakhir oleh T0mG
After upgrading to V57.0 Mozilla is almost impossible to use because it is so slow, for example taking 10 to 20 seconds to open (or close) a new tab. Won't maximise from taskbar icon when minimised (opening another tab before minimising then closing Mozilla from taskbar produces dialog box and maximises). Using Chrome to send this as Mozilla is too slow. Note that Chrome is working perfectly. Thanks
tg
After upgrading to V57.0 Mozilla is almost impossible to use because it is so slow, for example taking 10 to 20 seconds to open (or close) a new tab. Won't maximise from taskbar icon when minimised (opening another tab before minimising then closing Mozilla from taskbar produces dialog box and maximises). Using Chrome to send this as Mozilla is too slow. Note that Chrome is working perfectly. Thanks tg
Penyelesaian terpilih
hi, can you try if this change can workaround the performance problem?: go to the firefox menu ≡ > options > privacy & security panel and under permissions check the setting to prevent accessibility services from accessing your browser.
Baca jawapan ini dalam konteks 👍 7
Penyelesaian Terpilih
Thanks Philipp
